- This topic has 75 replies, 1 voice, and was last updated 4 years, 6 months ago by
DirtyWhiteBoy.
July 27, 2016 at 8:51 am #548312kurt@welkerhomes.com wrote:
It is both a catch and a shroud. I was amazed how much chips it held. it is odd to get used to emptying your saw.
Interesting concept, I wonder if that is in response to an upcoming safety requirement to contain sparks on the job site.
What requirements are those? I haven’t heard anything about it.
July 27, 2016 at 9:55 am #548335Anonymous
InactiveThanks Kurt for helping with the answers. It is a nice concept and pretty efficient.
Sven, I am just finishing my review , I really do loike the chip catcher, it works well.
It does, and the saw is really nice. Would like to take the 12″ chop saw for a spin some time. I’m sure that one is amazing as well.
Thanks Kurt & Sven, Yeah I’d like to try that 12″ Chopper myself. I wonder if it has a chip catcher too??
July 27, 2016 at 10:21 am #548342I wonder how fast the chip catcher fills up and what happens when it’s full?
July 27, 2016 at 10:42 am #548355Anonymous
InactiveI wonder how fast the chip catcher fills up and what happens when it’s full?
Good question, It would be a pain if it fills up fast and ya have to stop a lot to empty. Since it’s also the shroud the chips must get reground up by the blade til they can fly out the bottom or something, Sounds hard on the blade. I’m sure that would create a lot of heat too
July 27, 2016 at 11:39 am #548383redwood
ProI wonder how fast the chip catcher fills up and what happens when it’s full?
I would think there has to be some separation between the blade and where the chips are stored. It does seem like the shroud would fill up somewhat fast.
What type of metal work is this saw actually intended for. Metal roofing and siding?
Mark E.
Pioneer, CA
Working Pro 1972 - 2015
Member since Jan 22, 2013
www.creative-redwood-designs.comJuly 27, 2016 at 12:04 pm #548390Anonymous
I know a guy that has one and says he actually cut 2″ solid square stock with it. But as quoted in Svens review;
This saw, according to the manual which was included states that 2 ½” x 2 ½” x ¼” as the maximum. After cutting the stock that I had available, I can only assume this restriction is based only off of the blade size. I had no problems cutting the angle iron.
July 27, 2016 at 1:26 pm #548406It does seem like the shroud would fill up somewhat fast.
What I’m wondering if a guy needed to cut a mass of one length and went to the stack of 18ga. say 2×6 and pushed one full layer out and made a line would it cut them all say 20 of them with out filling up?
July 27, 2016 at 9:46 pm #548543I would say it would probably cut all of that without filling up. I had made a lot of miscellaneous cuts then cut a leg off of a channel that was about 2′ long and almost 3/8″ thick. After the second cut it was full and I emptied it, but that would equate to a lot of 18 GA studs
July 28, 2016 at 7:41 am #548681How fast it will fill up is directly proportionate to the thickness of the stock you are cutting. After the 10 cuts of angle it was getting pretty full, but it wasn’t close on the thinner aluminum.
July 28, 2016 at 9:56 am #548743How fast it will fill up is directly proportionate to the thickness of the stock you are cutting. After the 10 cuts of angle it was getting pretty full, but it wasn’t close on the thinner aluminum.
Must be like dust control trying to contain flying stuff at the work site. Guess if you have the saw you’ll have to monitor the chip catch and make sure to empty.
Fayetteville, NCJuly 28, 2016 at 1:24 pm #548819Can you see a cut line of do you need to make a off set line?
July 28, 2016 at 9:17 pm #548993Can you see a cut line of do you need to make a off set line?
I would say from the pics Sven posted
it will be hard to see the cut line. Not much of a sight window.
July 29, 2016 at 1:56 am #549057Can you see a cut line of do you need to make a off set line?
It looks like you just fallow the groove on the front of the table and do a hail marry.
July 29, 2016 at 8:45 am #549166it will be hard to see the cut line. Not much of a sight window.
Looks rather small and hard to see.
Fayetteville, NCJuly 29, 2016 at 12:18 pm #549267Anonymous
InactiveIs it possible to remove the chip catch and just let em fly? Probably not a good idea though
July 29, 2016 at 3:11 pm #549329Is it possible to remove the chip catch and just let em fly? Probably not a good idea though
@Dabbs,
Looking back at Sven’s picturesIt appears that there still is a blade guard but the chips shute looks like it would send the chips toward the user.
— Glenn BottingJuly 31, 2016 at 9:13 am #550089Is it possible to remove the chip catch and just let em fly? Probably not a good idea though
I don’t think that would be a good idea. I think the chips would fly back at you.
An offset line would make things much easier, but it could be done. I didn’t pay too much attention to it as I was just doin rough cuts. I was able to make some really thin cuts though sing the sight window.
July 31, 2016 at 9:36 am #550096:
Good point Sven. They probably want to contain the chips for various reasons.
Fayetteville, NCAugust 1, 2016 at 8:52 am #550467:
I can see breathing hot metal chips being detrimental to you health. lol.
August 1, 2016 at 9:10 am #550473Anonymous
Inactive:
Ouch lol, Yeah my buddy says with the one he’s got (I forgot the brand) he insists on using a full face shield because of the flying hot chips
