7/16 impact
Viewing 14 posts - 1 through 14 (of 14 total)
  • #547774
    vos
    oswego, NY
    #547818
    kswiss
    edmonton, AB
    I think they armostly used to run auger bits so you can use one hand without worrying about the drill getting ripped out of your hand.
    #547974
    Bosch makes one too, In fact it’s on the piggy list for ya. I have one and it’s great, 500ft lbs of torque and you can get an adapter to 1/2″ square drive for sockets. I carry it in my truck for flat tires etc, And it’ll drive the biggest of big auger bits. This one is an 1 1/2″ x 18″ long
    #547978
    nice , that thing is a beast , i only know of you and Sven that have them , I still have it on my long list of tools
    #547982
    Seven-Delta-FortyOne
    The Emerald Triangle, Northern California
    I know Milwaukee made one in the 28 volt line. I assumed they were like a small and portable version of an air impact.
    Delta
    Goin' Down In Flames........
    #547997
    Austin
    Covington, KY
    I wouldn’t mind getting one of those eventually. It would be nice to see them come out with one to compete with the other three brands out with at least doubled the torque.
    #548127
    Clev08
    I agree I’d love one off of the list but I want more torque. I’ll probably never need it, but I want it lol
    #548138
    Austin
    Covington, KY
    Don’t you already have Milwaukee stuff. The fuel one has 1200 pounds of torque. Just get that.
    #548154
    So why are people drilling holes with a impact driver?? Why not use a hammer drill?? I thought impact was for nuts bolts and screws and such.
    #548230
    Yeah that is what I thought too. Use the right tool for the job. I am sure the actions are different between impacts and the hammer drills.
    (and also the World's Fastest Poster)
    #548337
    jzmtl
    Montreal, QC
    Impact driver/wrench doesn’t transmit as much torque to your wrist, it’s mostly absorbed by the mass of the tool. No difference on small holes but on large holes you don’t need to brace the tool nearly as much. Not to mention if the bit is jammed a powerful drill can literally break your wrist.
    #548346
    I somewhat agree, I wouldn’t use one for drilling metal. It can’t be good on the bit or as accurate as a real drill, But they are better for drilling a big rough finished hole in wood for the reasons Jsm said below. I used to use a big spade bit with a powerful drill and when the bit catches/stops it’ll tear your arm off, I think we’ve all been there done that a time or two.
    #548350
    I can’t imagine ever needing that much torque, 500ft lbs in a hand impact is plenty
    #548384
    Austin
    Covington, KY
    Depends on what you are doing. If you were working on some heavy duty machines like a tractor and there was an old rusty bolt you might need all the power you can get.
queries. 0.409 seconds
