5" ro sander or rectangular sanders, which do you prefer?
Viewing 16 posts - 161 through 176 (of 176 total)
  • #391836
    rylim
    Missouri City, Texas
    I like the 5″ ro sander over the ¼ sheet sander any time.
    In fact I haven’t used the ¼ sheet any more now I have the RO 5″ and 6″ sander.
    You might get a RO with 5″ and 6″ interchangeable backing plate.
    I prefer 5in over 6in sanders for regular work. Just easier to use.
    #391856
    Mine had the 2 backing plates.
    #391941
    As does mine
    I prefer the 5 to get everything smooth, then (depending on the size of the workpiece) switch over to the 6 inch to make everything glassy and level.
    Also like the 6 (again, on larger surfaces) for light passes between coats
    #392240
    rylim
    As does mine
    For deep sanding, I prefer to use belt sander.
    #392261
    Most all of my sanding needs are done with my 18 volt 5″ ROS these days.
    #392268
    Each type of sander has its place in my book for furniture work, and I use them all. I use the belt sander for large material removal. I have two random orbit sanders which are good for general sanding, but because they sand in circles, you can see the cross-grain scratches when I put finish on. So I do final sanding with 220 grit on a 1/4 sheet oscillating sander (or sometimes a rubber sanding block for small pieces) to get the final surface.
    #426154
    Check this Sander Manual at http://www.manualbirds.com/manuals/makita-sander-user-manual-291499, you will see the difference.
    Troll!
    #426166
    Troll!
    SPAM and cheese!
    @ChadM
    #427002
    I use both orbital and rectangular. PT wood gets the 5″ 90% of the time, but i finish my Ipe’ with a 1/2 sheet rectangle sander 🙂
    #427265
    yellaD
    Dust extraction as you sand makes a big diff for me so I use a 6in Festool Rotex for when fast removal is needed, a 5in Mirka Deros I just got for moving up grits, and a delta sander for inside corners when necessary. All are used with dust extraction.
    The abrasive you use is important as well. Most stuff sold in BB stores is pretty lousy.
    I use the Rotex 6″ RO and a DTS 400 delta sander for corners. I donated my 1/2 sheet and handheld belt sander because they didn’t have dust extraction.
    BIG DIFFERENCE in enjoyment levels.
    #427567
    r-ice
    Durham region, ON
    I only have a porter cable 5 inch random orbital. I’ll eventually have to look for a newer and nicer one. I wouldn’t mind either the rotex or the mirka’s
    #427768
    Toolshead
    In the Rice Fields, South TX
    Seems I’m the only one with a dedicated sanding station?
    Just a box with a pegboard top and a piece of 4″ PVC through the side to hook up to the DC. Sand away, and the sawdust disappears through the top of the box. Vary the suction by covering different parts of the top.
    #427791
    yellaD
    I was going to incorporate a little area like that in something else, maybe like my sharpening pond/stones area.
    Did you caulk or seal the inside of the box?
    #427853
    crotalusco
    west bend, wi
    I tend to use belt, orbital and standard sanders on most of my projects. Each have their uses and specialties
    #427940
    1/2 sheet is a go to for larger areas and field work. A random orbit is good between finish coats and final sanding at higher grits. I like an orbital delta for corners too. I dual mode replaced my belt sander and it has much better DC anyway.
    Orange County, CA
    #428074
    r-ice
    Durham region, ON
    When I rearrange my shop, I may do this, as this would make the most amount of sense. I wonder if it would be counter productive if I have a hose coming in from each side .
queries. 0.838 seconds
