- This topic has 296 replies, 35 voices, and was last updated 3 years, 11 months ago by
r-ice.
March 5, 2017 at 10:42 am #613867
I’ve been using a hako soldering iron it has a digital readout I just usually stick to 650 for temperature. I’ve 3d printed a bunch of accessories to help me manage things a bit better. I always shrink wrap everything I can’t risk any shorts.
March 5, 2017 at 12:28 pm #613882I’m working on my printers today actually
is that your basement or garage? looks very organized in there 😀
Palm Springs, CAMarch 5, 2017 at 1:10 pm #613884I’ve been using a hako soldering iron it has a digital readout I just usually stick to 650 for temperature. I’ve 3d printed a bunch of accessories to help me manage things a bit better. I always shrink wrap everything I can’t risk any shorts.
Nice, I’ve been thinking to upgrade to a Hako station as my old Weller WES51 has lost heat control. I’ve had to resort to using an old plain jane iron.
I really like that vice you made.
— Glenn BottingMarch 5, 2017 at 3:20 pm #613895I’m working on my printers today actually
Haha I wish, this is at the local makerspace where I do most of my work on this stuff. I have limited room at my place and they have all the tools and materials I need available.
March 6, 2017 at 5:23 am #613963I’ve 3d printed a bunch of accessories t
Kyle did you print that small vice in your photo? If so very nice.
Fayetteville, NCMarch 6, 2017 at 6:28 am #613977I’ve 3d printed a bunch of accessories t
I did, and it actually works very well
March 6, 2017 at 8:43 pm #614137Whipped up in CAD and then 3D printed this bit clip for my Dewalt impact driver tonight. I often find myself using the impact driver for countersinking after I drill but then the screwdriver bit runs away… no longer!
March 7, 2017 at 5:09 am #614164I’ve 3d printed a bunch of accessories t
Those are both very nice projects guys. Kyle that vice is nice. Robotmaster always handy to have a bit holder. Kyle where did you find the pattern for the vice?
Fayetteville, NCMarch 7, 2017 at 6:32 am #614179You can find the files for the machine vice here http://www.thingiverse.com/thing:2064269
March 7, 2017 at 8:21 am #614203fishguy3
ProWe use 3D printers at work. They are amazing although it takes some time to make something. The ones I have experience with are great if you are making some sort of a jig but if your making something that moves or a tool we have had limited success. I believe the ones we have are probably a little older right now and entry level. I hope this helps.
Mark
March 7, 2017 at 8:27 am #614205Whipped up in CAD and then 3D printed this bit clip for my Dewalt impact driver tonight. I often find myself using the impact driver for countersinking after I drill but then the screwdriver bit runs away… no longer!
Very nice. Great job.
@kswiss wow Kyle super work and projects you have been making.Have you thought about making a 5/8 to 1/4 adapter for Alex madman_us Bosch floodlight to mount on the tripod?
I’m sure you can do that easily. Probably cost 50 cents and about 25 dollars for shipping lolMarch 7, 2017 at 8:30 am #614206Lol that’s the problem, everything is really cheap to make but the cost of shipping is insane. Unless you can stick it in a small envelope your looking at like $10 minimum for shipping costs.
March 7, 2017 at 8:40 am #614207Whipped up in CAD and then 3D printed this bit clip for my Dewalt impact driver tonight. I often find myself using the impact driver for countersinking after I drill but then the screwdriver bit runs away… no longer!
@robotmaster5379.
Neat clip to hold bits.
How did you mount the clip? is it glued on or double sided tape?“If you don’t pass on the knowledge you have to others, it Dies with you”
— Glenn BottingMarch 7, 2017 at 8:42 am #614208Ya I was also wondering how it’s mounted, it looks like a good fit. Was that printed in PLA?
March 7, 2017 at 8:46 am #614209Whipped up in CAD and then 3D printed this bit clip for my Dewalt impact driver tonight. I often find myself using the impact driver for countersinking after I drill but then the screwdriver bit runs away… no longer!
@robotmaster5379.
How did you mount the clip? is it glued on or double sided tape?Must be with the small threaded holes that the majority of drills / impacts have for the original belt clips I would guess
March 7, 2017 at 1:20 pm #614265Whipped up in CAD and then 3D printed this bit clip for my Dewalt impact driver tonight. I often find myself using the impact driver for countersinking after I drill but then the screwdriver bit runs away… no longer!
@robotmaster5379.
How did you mount the clip? is it glued on or double sided tape?There is a M3 screw hole in the body of the driver. I measured the area with calipers to design it to fit around the rubber boss, with a M3 counter sunk screw.
March 9, 2017 at 4:59 pm #614630I’ve been using a hako soldering iron it has a digital readout I just usually stick to 650 for temperature. I’ve 3d printed a bunch of accessories to help me manage things a bit better. I always shrink wrap everything I can’t risk any shorts.
how do you like your hako? i got mine late last year and i think its a great little soldering set up that will probably last me a life time.
