3 Way Track Saw Showdown
Viewing 6 posts - 241 through 246 (of 246 total)
  • #617479
    @Austin wrote:
    Fast cap makes a in line switch that you plug into the walk then the vacuum into it and can turn on the vacuum with a remote. I am going that route.
    I haven’t seen that one Do you have a linky
    #617490
    That Festool cordless sure looks sweet, comes with 2 batteries and 2 chargers since it uses 2 batteries. For the kit with a track is about exactly double what the Makita is, but the more I think about it the more I want one. Help!
    I will stick with my corded one just because of the vac hose, It’s hard to be cordless with a vac hose on the tool.
    That’s how I figure it as well. Unless you are using a dust bag, what’s the point of going cordless for the power.
    It’s the power cord that also triggers the vac to go on and off.
    My “poor man’s track saw” (an 18v circ saw on a track) is often hooked up to my 18v vac. Sure, there is a small hose, but I dont need to run any wires, and I can cut just about anywhere- including the home depot parking lot
    #617493
    Yesir! I think you should have them. Plus the DeWalt ones are cheap insurance. 32 bucks for 2 clamps is a no brainer IMO
    Are these the ones??
    #617502
    CrpntrFeak
    Globe, AZ
    Those are them! I like them because they are not as awkward to get at when under your work
    #617526
    brianpeters
    Murray, KY
    I have a set of these coming as well
    #617555
    Austin
    Covington, KY
    @dirtywhiteboy
    http://www.fastcap.com/estore/pc/viewPrd.asp?idproduct=45290&idcategory=285
    Going to get a couple of these probably. They have 4 channels.
queries. 2.396 seconds
