2×4 End Pieces?
Viewing 20 posts - 21 through 40 (of 44 total)
  • #476790
    r-ice
    Durham region, ON
    with wood movement the gaps might get bigger or smaller throughout the seasons. However this company does it, they may be able to give you some pointers.
    http://kaswell.com/
    it does look nice though, probably would be more expensive than regular flooring for sure.
    #476844
    TopNotch
    elmwood park, NJ
    If they were laid flat and allowed to dry without cupping I think the poly might prevent absorbing humidity.
    I dont think its a good idea, Its the weakest part of the grain and I could see dropping something on it being a problem.
    Working Pro since 1993
    Tom M
    #476848
    r-ice
    Durham region, ON
    unless they dropped a chisel, i think everything else will be fine, look at end grain cutting boards, they have stuff chopped and sliced and they usually do pretty good.
    #476867
    End grain boards are hardwood, not softwood; this project might look cool but unless you are doing it for yourself I think the labour costs would be too much.
    Will
    #476878
    TopNotch
    elmwood park, NJ
    End grain is the weakest part of wood. Fibers are not bound together like flat or edge grain.
    Tom M
    #476880
    Yes that’s my exact thought, unless I’m missing something. What sort of glue would be used to adhere the wood end cuts?
    #476883
    Won’t this crack horribly as the wood expands and contracts with humidity, weather? Seems like a bad idea with end grain. That said, I really like that look.
    #476942
    Found another company that specializes in end grain flooring. They even claim it has been used for a long time and in fancy places. If this is the look you are going for, I would buy the pre are product. Most Pinterest posts are casual diyers who are trying to save a dollar and don’t realize the difference in quality let alone type of wood.
    http://www.kennebecwood.com
    Anything is possible if your wallet is thick enough ~ my father
    #476973
    redwood
    Using 2×4 endcuts would be painfully slow, I would think.
    If the material was dry and solid it could work, but I think it’s a labor nitemare.
    Mark E.
    Pioneer, CA
    Working Pro 1972 - 2015
    Member since Jan 22, 2013
    www.creative-redwood-designs.com
    #476979
    MrFid
    Sudbury, MA
    There are lots of problems I see, and they’ve been mentioned. You could probably do it, but why would you want to? More trouble than it’s worth. There are better ways to get a unique, rustic look if that’s what you’re after. Bricking, or wide roughcut barnwood would give a rustic look without as much trouble, either at install or later down the line.
    #476980
    I wonder if there is an engineered floor that has that design out there .
    Always willing to learn .
    #476990
    Especially since she THINKS it would be cheaper because of the material,
    Epoxy is expensive.
    #476993
    If they are sealed in epoxy they aren’t absorbing anything or moving anywhere. Wood is used to laminate windsurfing and surfing boards and it’s the strongest martial they can use.
    #477009
    For most things the material part is the cheapest part of the total cost. It all depends on what you select. ceramic tile at a buck a SF costs the same to lay as ceramic tile you pay 6 bucks a SF, the same for hardwood. Cheap costs the same to install as more expensive exotics for the most part. A floor like that would have a ton of labor.
    #477069
    WoodsConstruction
    Sudbury, ON
    Epoxy is expensive.
    Well with any HO they only consider the visible material / product. They never seem to think of fasteners / epoxy’s / grout / mud / whatever holds things together haha
    #477071
    Epoxy is expensive.
    Agreed ,, I know that one all to well.
    #477074
    It looks to be pretty popular these days , I would do a bit of reading up first before I would consider doing it .
    https://www.bing.com/images/search?q=end%20grain%20flooring&qs=AS&form=QBIRMH&pq=end%20grain%20floor&sc=3-15&sp=1&sk=
    #477094
    I think I would seal all sides before installing if I were going to do it then epoxy over that.
    I was at a meeting in a barn that one of the Mayo brothers of the Mayo clinic fame had built on his farm. The floors where the horse stalls were, were white oak 4 x 6’s about a 6″ long all set in place with the end grain showing just like stone pavers. The barn is now a conference center. It was about a hundred years old. They used the oak because it was easier on the hooves of the horses than stone or concrete would have been. It was quite a striking floor. I wish I had taken a photo but I did find this one online. the oak is in the center and the outer edges that are diagonal are pavers.
    #477165
    Epoxy is expensive.
    How large of an area would this floor be? I’m assuming we are talking about a couple thousand of dollars of epoxy…
    #477207
    WoodsConstruction
    Sudbury, ON
    Epoxy is expensive.
    She was looking to have around 220 sq ft done, but I think I’ve got her convinced on some nice rustic wood looking 6×24 tile.
queries. 0.679 seconds
