- This topic has 34 replies, 7 voices, and was last updated 2 years, 1 month ago by
kurt@welkerhomes.com.
August 7, 2018 at 3:19 pm #692405
We started this house a couple weeks ago. It is a 2.100 SF walkout ranch. With the wet weather we have had, it has been a little slow due to the additional soils work we have had to do.
The site sits above the 100 year flood line but still low in relation to the street and surrounding area. We stripped the topsoil over the entire footprint of the house and garage. We hauled in about 500 ton of coarse sand to build our base, that was about a foot and a half to two feet thick. We then placed and compacted about 3 feet of clay on that to bet to an elevation that was about a foot below the basement floor. For the garage area we placed and compacted another 7 feet of clay to build up that area. in all so far we have hauled in about 2,500 CY of material We will need probably about 1/2 that much more to build up around the foundation.
The last couple of homes we have done we have used a precast foundation system. We started by placing 8″ of clean crushed rock on the subgrade and compacting that and grading it to provide a base for the panels. The nice thing about this foundation system is that it installs in a day. Below are some photo’s for the system installed ready for rough in plumbing and framing.
August 8, 2018 at 12:09 am #692479We started this house a couple weeks ago. It is a 2.100 SF walkout ranch. With the wet weather we have had, it has been a little slow due to the additional soils work we have had to do.
That’s a nice system. Is that foam and metal on the walls ready for sheet rock?
August 8, 2018 at 5:37 am #692482The last couple of homes we have done we have used a precast foundation system. We started by placing 8″ of clean crushed rock on the subgrade and compacting that and grading it to provide a base for the panels. The nice thing about this foundation system is that it installs in a day. Below are some photo’s for the system installed ready for rough in plumbing and framing.
So, am I understanding that the 8″ of compacted rock is the footing for the panels? How are the panels joined together? How is the exterior of the system waterproofed?
Even if you can’t Be The Pro… Be The Poster you’d want to read.August 8, 2018 at 8:09 am #692513We started this house a couple weeks ago. It is a 2.100 SF walkout ranch. With the wet weather we have had, it has been a little slow due to the additional soils work we have had to do.
Pretty interesting system , I see in the second photo , it looks as if those panells got sprayed white on the inside of the foundation , will that be the same for the back where the walk out is , this will be a nice learning thread to follow ,
August 8, 2018 at 9:17 am #692527Yes, the foam and metal studs come on the panels and the interior is ready for drywall. There is a little framing necessary at the corners to have proper drywall backing there.
The 8″ of compacted rock is the “footing of the system. The panels are a 5000 psi concrete which in fairly impermeable to moisture. additional we spray them with a waterproofing from grade to the base of the panel.
The panel is made so the joints are basically a ship lap then the joint gets 3 beads of sealant on that lap. In addition to that they re bolted together top and bottom and a few times in the middle.
That is actually the color the panels come. they far a fairly nice clean exterior.
The second photo is the garage. they use a white bead board for the insulation on the garage in lieu of the more expensive extruded foam on the areas that do not get buried. Not as much insulation is needed in those locations below grade.
August 8, 2018 at 12:44 pm #692547The 8″ of compacted rock is the “footing of the system
So you get your compact rock so good you can set them and build your floor with out leveling it off?
August 9, 2018 at 11:28 am #692645kurt@welkerhomes.com wrote:The 8″ of compacted rock is the “footing of the system
They set small metal screeds in the rock then shoot them in with a laser. Then they use the screeds to level the rock after it is compacted. surprisingly the top of the panels are pretty true to elevation when done. All the corners are set with a total station so the dimensions come out right on and square.
August 9, 2018 at 12:29 pm #692657kurt@welkerhomes.com wrote:The 8″ of compacted rock is the “footing of the system
This sounds like a very good system. Can you give the name of this precast walls so I can you-tube them or is it a local yard doing them?
August 9, 2018 at 5:45 pm #692681kurt@welkerhomes.com wrote:kurt@welkerhomes.com wrote:The 8″ of compacted rock is the “footing of the system
https://www.superiorwalls.com/ Ours come from Michigan, there are others that do them in other places in the country
August 27, 2018 at 12:42 am #694911How’s this one coming along Kurt,
I know you have been extremely busy, just curious to know how the progress is coming along,August 27, 2018 at 1:09 am #694915kurt@welkerhomes.com wrote:kurt@welkerhomes.com wrote:The 8″ of compacted rock is the “footing of the system
That looks like a great system.. I found some info on the you-tube,, for all to see.
August 27, 2018 at 6:10 am #694930I found some info on the you-tube,, for all to see.
Thanks Dirty, looks like a great system.
Fayetteville, NCAugust 27, 2018 at 9:25 am #694948That looks like a great system.. I found some info on the you-tube,, for all to see.
Thanks for the links, That looks like a really good system. I like the simplicity.
Even if you can’t Be The Pro… Be The Poster you’d want to read.August 27, 2018 at 5:47 pm #694999Neat system. 2100 sq ft is a nice “normal” sized house too. Much better than all the tacky McMansions I see go up.
My You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA
I don't do a fast job. I don't do a slow job. I do a half fast job.
August 27, 2018 at 6:24 pm #695001With what we are finishing in the basement, there will be about 4000 finished.
I will get more photo’s tomorrow.
August 27, 2018 at 10:49 pm #695032So how thick it the concrete in the walls. I guess it’s strong enough to hold the weight of the back fill. I guess at some point you pour the slab on the inside.
August 28, 2018 at 5:39 am #695048The concrete on the face is about 2″ thick, with concrete studs every 16″. after the panels are set, we get the plumber in right away and install the underfloor plumbing. Once that is done we pour the floor and install the main floor before we back fill. We are setting trusses now but rain has held up up a fair bit.
We have hauled over 4000 CY of soil into this site to get the grades where they need to be. with all that fill, rain is a real factor. We try to stay out of the mud as much as possible since the forklift ruts up the site so bad. Fortunately, we have some other places we can work that are inside or at least out of the mud.
August 28, 2018 at 7:19 am #695059We have hauled over 4000 CY of soil into this site t
Sounds like a big job, the landscaping alone was a big job.
Fayetteville, NCAugust 28, 2018 at 10:19 am #695083@DirtyWhiteBoy thanks for those videos,
Interesting process,August 28, 2018 at 11:35 am #695093The concrete on the face is about 2″ thick, with concrete studs every 16″. after the panels are set, we get the plumber in right away and install the underfloor plumbing. Once that is done we pour the floor and install the main floor before we back fill. We are setting trusses now but rain has held up up a fair bit.
It sounds like you have a sub do the prefab walls. How does the cost compare with forming and pouring your own walls? Do you think this is stronger& better than doing your own pour in place walls?
