- This topic has 26 replies, 14 voices, and was last updated 4 years, 10 months ago by
theamcguy.
May 23, 2016 at 9:16 am #519861
JourneyMan
ProAnyone else used 1Step underflooring in basements? I have to say I’m very impressed at first use, our client was a little hesitant at the cost first but we won him over showing him the added benefits of the material in his new basement project.
1Step
Project started
Near complete
Floored …Carpenter and Joiner
Joiner ... a person who constructs the wooden components of a building, such as stairs, doors, and door and window frames.
Carpenter ... cutting, shaping and installation of building materials during the construction of buildings, ships, timber bridges, concrete formwork.
1970 ... to present.
May 23, 2016 at 9:52 am #519865That looks like a good product. We have never tried it. The finished product looks great
May 23, 2016 at 10:15 am #519871Interesting product,i haven’t had first hand use of it. I’ll have to read up on it and since you are within a couple hour drive, I should be able to get a hold of the 1 step should I need .
May 23, 2016 at 10:17 am #519873wbembrid
ProThat looks like a good product. We have never tried it. The finished product looks great
It does look great; this might sound weird, but could you describe both how it sounds and feels when you walk on it?
Will
May 23, 2016 at 10:35 am #519882Delta-FL or Platten are the only procudts I have used.
Platten is a fraction of the cost of any other underlayment flooring product out there.
— Glenn BottingMay 23, 2016 at 12:57 pm #519938JourneyMan
Prokurt@welkerhomes.com wrote:That looks like a good product. We have never tried it. The finished product looks great
Surprisingly quiet and soft … so much so that our client remarked on the product when he stepped in from the garage stairs … “it goes down a little when I stand on it” he said … I replied … good, that’s what it’s meant to do.
Our client also has a pool table to install down in the basement but I researched that too and found it’s pool table safe.
May 23, 2016 at 1:03 pm #519939JourneyMan
ProDelta-FL
We looked at Delta FL but 1-Step seemed to come out on top in many aspects …
May 23, 2016 at 1:17 pm #519954Looks like a nice product. Did you get it from a distributor? I haven’t seen it around, but then I don’t work a lot with flooring distributors.
May 23, 2016 at 1:53 pm #519963Looks a lot nicer than the stuff I just put down. Are all the lengths the same. I can’t tell.
May 23, 2016 at 3:17 pm #519988JourneyMan
ProLooks like a nice product. Did you get it from a distributor? I haven’t seen it around, but then I don’t work a lot with flooring distributors.
Rona was our guys but now they are part of Lowes.
It’s the underlay material we are talking about.
May 23, 2016 at 5:41 pm #520026Doobie
ModeratorDelta-FL or Platten are the only procudts I have used.
I used Platon as well. Can give off a clanky sound.
I saw the one Journeyman shows at HD just two days ago in passing. It is softer and less hard plastic than the Platon product. I just touched it briefly, but it felt like a super compressed foam like material if that makes sense.
May 23, 2016 at 6:18 pm #520056I’ve never used it…but it looks a bit like Schluter Ditra. I’ve used that for tile underlayment a couple of times.
InstagramMay 30, 2016 at 7:23 am #522694We looked at Delta FL but 1-Step seemed to come out on top in many aspects
Looks like a good product but at the time I did my basement I had two choices Delta-FL or Dri-Core. I do get some click but only at a couple of the edges/ends. None what soever in the center of my floor. (700 sq ft) Been down for about 8 years now and never an issue with the laminate I put down.
I have seen the DMX-1 product at my local HD.
@journeyman,
Here is the thread I started. http://bethepro.com/forums/topic/keeping-my-basement-floor-warm-dry/“If you don’t pass on the knowledge you have to others, it Dies with you”
— Glenn BottingMay 30, 2016 at 8:23 am #522718Delta-FL
<figure class=”oe-video-container”><iframe width=”770″ height=”433″ src=”https://www.youtube.com/embed/QaplXLQTzkM?feature=oembed&wmode=opaque” frameborder=”0″ allowfullscreen=””></iframe></figure>
Looks like a good product, it’s saying it is a dense foam underlying, I assume it would not absorb any moisture, I always like these products with the air flow little egg shapes, great for letting the air and concrete breath.
Nice job on the basement floor by the way, I like the color,
May 30, 2016 at 10:35 am #522776JourneyMan
ProDelta-FL
The HO picked the laminate out, in fact they bought it at a warehouse place I recommened. It was called Earl Grey (like the tea)
May 30, 2016 at 12:52 pm #522798asgoodasdead
ProI might use this stuff for my basement
May 30, 2016 at 1:38 pm #522815It looks like a good product JM I’m wondering how much hight it adds to the flood so when the wood hit say tile?? The transition strip?? Will it still work?
May 31, 2016 at 7:06 am #523146Mervyn the results came out looking great.
Fayetteville, NCMay 31, 2016 at 7:16 am #523158JourneyMan
ProIt looks like a good product JM I’m wondering how much hight it adds to the flood so when the wood hit say tile?? The transition strip?? Will it still work?
Together with 12mm laminate flooring altogether raises the floor 1 inch. Transition strips more than likely adds another 1/4 at doorways etc.
May 31, 2016 at 8:40 am #523175I might use this stuff for my basement
One of the best upgrades to any basement. I’d recommend it to anyone who wants to finish their basement.
— Glenn Botting -
